文章
Using a remote with BuildIT
Laser trackers are often used to measure very large parts, and so users are usually inconveniently far from the measurement buttons while manipulating the probe. This leaves you with three options to measure a large part:
1. Have someone at the computer while you manipulate the probe
The inspection of a large part can often be a team effort, and when you have the luxury of being two, your colleague can manage triggering the correct buttons.
2. Use the “Auto-start when stable” feature, combined with the “Auto-accept” feature
The measure button can be automatically triggered when BuildIT detects that the probe is resting against a stable object. This option can be accessed by clicking the Setting button in the upper left corner of the Inspect Control Window:
Sample Points Distance
Click the checkboxes to turn on the feature. In the example below, it will start measuring when the probe hasn’t moved more than 0.25 mm for 3 seconds. After taking its measurement, it will wait until you have moved at least 127 mm from your last measurement before auto-starting when stable.
Auto Measure
Similarly, you can also have the Accept button automatically trigger a certain length of time after taking a measurement.
3. Use a remote
This is my preferred way of measuring, as it gives you full control of the buttons with no ambiguity. You simply need to assign the buttons on the remote to the desired hotkeys: F9 to measure, F10 to accept, F11 to discard last, F12 to send your beam to the bird nest.
It’s important to choose a remote that will work over long distances, especially when inspecting large parts. One that is usually used in the industry is the SMK-Link’s RemotePoint Jade, which works at a range of up to 150 feet.
文章
质量控制和检测
航空航天
汽车
软件 - 测量与质量控制
质量控制和检测 (BP)
倡导
FARO Insights
筛选
筛选
