ウェビナー/プレゼンテーション録画
Creating compelling 2D & 3D deliverables from photos
ダウンロードの準備が整いました!
このコンテンツにアクセスしていただくために、もう少し詳しく教えていただけますか。
購読者は、各メール通知の下部に記載されている登録解除リンクをクリックすることで、いつでも同意を取り消すことができます。私たちはあなたのプライバシーを真剣に受け止めます。FAROがお客様の個人情報をどのように処理するかについての詳細は、 当社のプライバシーポリシーをご覧ください。
[送信] をクリックすると、FARO またはその公式パートナー/販売代理店からの回答を受け取ることに同意したとみなされます。
Discover how to create impressive and dynamic deliverables for your next presentation or case using FARO Zone 3D Software.
Are you getting the most out of your field evidence?
Did you know you can create powerful, shareable deliverables in the software, FARO® Zone 3D? By using something as simple and commonplace as a photograph, you can make animations, generate measurement reports, create report diagrams, do time distance studies, perform skid analysis and more.
Join us for this webinar to take a closer look at what you can do with FARO Zone 3D and see examples of various different deliverables created from a single photograph – even if you don't use a Laser Scanner! Attendees will learn how to create four different 2D and 3D deliverables from one single image all from FARO Zone 3D Software.
Watch this webinar to learn how to create the following from a single photo - all sharable to anyone, without software/access requirements:
  • VIRTUAL SURVEY – a full measurement report and a data set
  • DIAGRAM – a complete diagram with measurements, North arrows, scale bars and forms
  • TIME DISTANCE – a detailed report generated in FARO Zone 3D
  • ANIMATION – an easily viewed MP4 video
Presenter: Dean Pierson | Application Engineer, FARO Zone Trainer
Dean Pierson is our trainer for FARO Zone 3D crash and crime. He is based in Kamloops, British Columbia, Canada and delivers course content online to FARO customers all over the world. Dean grew up in a law enforcement environment with a father that served with the Royal Canadian Mounted Police.
Host: Alina Burroughs | Application Engineer, Global Senior Public Safety - Forensics Specialist
Special Guest: David Rineholt | Accident Investigation/Reconstruction Expert
Special Guest: Derik White | Product Director, Research & Development of FARO Zone
ウェビナー/プレゼンテーション録画
クラッシュ再現
法廷でのプレゼンテーション
科学捜査エンジニアリング
警察
ソフトウェア - 公共の安全と犯罪科学
FARO Zone
再現と分析
検討
ニュースレターを購読して最新情報を入手してください。
関連コンテンツ
フィルタ
フィルタ
