Articolo
10 motivi per utilizzare la scansione laser per la scientifica
Laser scanning is rapidly gaining acceptance and becoming more and more commonplace in the law enforcement and accident reconstruction communities. Over the past few years, hardware and software have improved significantly creating a simpler, overall system to capture immense detail in a short period of time.
These are 10, of the many, reasons to consider laser scanners for a forensic application:
1) Easy to use: Many manufacturers are moving toward a simpler interface making operation of the scanner more like a digital camera than a complicated survey instrument.
2) Portability: Laser scanners are smaller in size today than ever before making them easier to deploy to a crime/accident scene and useable by just about anyone.
3) Safety: Data can be collected from a distance, with some scanners collected measurements over 300 meters away. This allows the operator to scan a scene out of harms way. In addition, laser scanners can collect up to 1,000,000 points per second with average scan times of several minutes. Less time on a scene means less time for potential danger to the individuals at the scene. Class I lasers are also being used in laser scanners creating a truly eye-safe environment during the scan.
4) Speed and Efficiency: Complete color scans can be captured in as little as several minutes creating a virtual scene with high accuracy and detail that can be revisited over and over without physically traveling to the site. In contrast to traditional methods of surveying/documenting a scene, laser scanning can be much faster and allow multiple investigators to have eyes on the virtual scene.
5) Produce a variety of deliverables: Once the scene has been laser scanned, various types of final products can be extracted or produced from the data. For example, anything from a traditional 2D drawing to a detailed 3D animation can be created from the scan data.
6) Pressione tra pari: con sempre più agenzie che utilizzano laser scanner per la loro documentazione di scena, il risultato è più ampiamente accettato. Così come la crescita delle aspettative che le scene future saranno documentate in 3D.
7) Efficace: i laser scanner stanno diventando sempre più paragonabili nel prezzo al totale delle stazioni tradizionalmente utilizzate per documentare gli incidenti stradali.
8) Strumenti di misurazione specializzati: il software per l'analisi forense da dati 3D ora include anche strumenti speciali per misurare gli schizzi di sangue e la traiettoria dei proiettili, l'altezza del testimone / sospetto, ecc.
9) Facile da condividere: sono disponibili più strumenti software per visualizzare e documentare i dati di scansione senza la necessità di installare software o acquistare licenze aggiuntive.
10) Archivia la scena: una volta che la scena è stata scansionata al laser, è stata sostanzialmente congelata nel tempo, conservata per future visite virtuali da parte di chiunque desideri indagare sulla scena. Ciò consente di effettuare misurazioni che potrebbero non essere state necessariamente ritenute importanti anche al momento dell'acquisizione.
Articolo
Sostegno
Consapevolezza
Raccolta
Prosecuzione e gestione
Ricostruzione e analisi
Indagini su incendi dolosi
Presentazione in tribunale
Ricostruzione di incidenti
Indagini sui guasti
Preservazione storica
Pianificazione della sicurezza
Incendi e soccorso
Ingegneria forense
Assicurazioni
Forze dell'ordine
Acquisizione di foto 360
Scanner 3D
Sistemi di mappatura mobile
CAM2 Zone
WebShare
