10 raisons d'utiliser le balayage laser pour la police scientifique
Laser scanning is rapidly gaining acceptance and becoming more and more commonplace in the law enforcement and accident reconstruction communities. Over the past few years, hardware and software have improved significantly creating a simpler, overall system to capture immense detail in a short period of time.
These are 10, of the many, reasons to consider laser scanners for a forensic application:
1) Easy to use: Many manufacturers are moving toward a simpler interface making operation of the scanner more like a digital camera than a complicated survey instrument.
2) Portability: Laser scanners are smaller in size today than ever before making them easier to deploy to a crime/accident scene and useable by just about anyone.
3) Safety: Data can be collected from a distance, with some scanners collected measurements over 300 meters away. This allows the operator to scan a scene out of harms way. In addition, laser scanners can collect up to 1,000,000 points per second with average scan times of several minutes. Less time on a scene means less time for potential danger to the individuals at the scene. Class I lasers are also being used in laser scanners creating a truly eye-safe environment during the scan.
4) Speed and Efficiency: Complete color scans can be captured in as little as several minutes creating a virtual scene with high accuracy and detail that can be revisited over and over without physically traveling to the site. In contrast to traditional methods of surveying/documenting a scene, laser scanning can be much faster and allow multiple investigators to have eyes on the virtual scene.
5) Produce a variety of deliverables: Once the scene has been laser scanned, various types of final products can be extracted or produced from the data. For example, anything from a traditional 2D drawing to a detailed 3D animation can be created from the scan data.
6) Peer pressure : Avec de plus en plus d'agences qui utilisent des scanners laser pour la documentation de leurs scènes, le résultat est plus largement accepté. De même que l'on s'attend de plus en plus à ce que les futures scènes soient documentées en 3D.
7) Rentabilité : Le prix des scanners laser est de plus en plus comparable à celui des stations totales qui sont traditionnellement utilisées pour documenter les accidents de la circulation.
8) Outils de mesure spécialisés : Les logiciels d'analyse médico-légale à partir de données 3D comprennent désormais aussi des outils spéciaux pour mesurer les éclaboussures de sang et la trajectoire des balles, la hauteur des témoins/suspects, etc.
9) Facile à partager : D'autres outils logiciels sont disponibles pour visualiser et documenter les données scannées sans avoir à installer de logiciel ou à acheter des licences supplémentaires.
10) Archivez la scène : Une fois que la scène a été scannée au laser, elle a été essentiellement figée dans le temps, préservée pour de futures visites virtuelles par toute personne qui souhaiterait enquêter sur la scène. Cela permet de prendre des mesures qui n'ont pas nécessairement été jugées importantes au moment de la capture.
Promotion
Prise de conscience
Collecte des données
Poursuites judiciaires et gestion
Analyse et reconstitution
Enquêtes sur les incendies criminels
Présentation devant les tribunaux
Reconstitution d'accident
Enquêtes sur les défaillances
Conservation du patrimoine
Sécurité incendie et sauvetage
Ingénierie médico-légale
Assurance
Application de la loi
Capture de photos à 360°
Scanners 3D
Logiciel : Sécurité publique et médecine légale
FARO Zone
WebShare
Filtres
Filtres
