Reverse engineering with RevEng Software is now easier and faster than ever. Users can scan with a FARO® ScanArm (paired with the optional 8-Axis to increase acquisition speed), or import point cloud files from any source to generate a mesh of the highest quality and quickly produce exportable CAD surfaces for downstream applications like machining,finite element analysis (FEA) simulations or 3D modeling.
RevEng's Automatic NURBS Surfaces Creation makes it the most affordable reverse engineering software, with a Scan-to-CAD workflow that is lightning fast.
This new tool allows you to:
- Create a full network of curves and surface patches in seconds and export it to a CAD file with one click
- Customize the surface patches with flexible control point placement, allowing full control
- Quickly verify continuity with color-coded curves
Other improvements in this new version include:
- Easily review deviations by adjusting the range of colors
- Better downstream workflow and applications with feature-preserving remeshing
- Additional information on the Info panel (such as number of holes and whether or not the mesh is watertight), ready to export
Sign up for a free trial today and see for yourself how easy it is to reverse engineer with RevEng!
